My Metrologic Voyager MS9520-Scanner with MX009-USB-Power-Link-Cable (changed with Keyoard-Wedge) permanently repeats an beep-green-led-red-led.sequenz if you power on - USB or Powerlink or both makes no different. I have also scanned all Barcodes of the handbook to stop this problem - without an result.
Can you help me? Is there a way to reset the scanner?
SOURCE: Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
SOURCE: Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
SOURCE: We are using a Metrologic MS9520 (keyboard wedge)
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
