2001 Saab 9-3 Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAAB 9-3 radio problems
I have a 2001 SAAB 9-3 with 2 radio problems. 1-many of the lights on the radio display are not lit.
2-when i turn left the radio switches from radio to cd.
Any suggestions?
Thanks
Anonymous
Level 2:
  • Expert 271 Answers
  • Posted on Apr 30, 2010
Anonymous
Expert
Level 2:
Answers
271
Questions
0
Helped
114041
Points
561
You have blown bulbs on a radio panel.Need to remove the radio,useing special 4 pins tool and change blown bulbs. 2-What about the steering wheel joystick-can you change from radio to cd? If so,problem in a contacts in switch.
My radio on SAAB 9-5 does not pick FM signals
You're a bit vague about the problem mate. Does the radio pick up AM or LW? Not sure what country you're in. Does the radio actually go? Check the aerial connections. Is this car imported from another country with different frequencies? You may need a band expander if this is the case.
Hazards spontaneously turned on and won't turn-off in 2001 Saab 9-3
try going to a saab dealer and ask if a merchanic could give a bit of free advice an where the onstar cpu is.
martyn
My 2003 Saab 9-5 Aero 4-cyl Turbo Won't start. However, I have power in car, lights windows and radio works. But it won't turn-over. It could be Starter or Starter Relay. I can't find out
Ok, those systems might still work because the not require as much energy as the starter. Check the Battery Voltage with a good Voltmeter. If below 12, there might be your problem!
2001 saab 9-3
Kind of an odd problem. This may be off in a different direction but I had an 78 BMW that the left turn signal did the same thing .It turned out to be the hazard light switch had a short in it. The problem was intermittent and very frustrating. The fix was a trip to the junk yard for a set of rims and the switch was a freebie. Don't know if this will help but I guess it can't hurt.
2helpful
Trying to replace the headlight of my Saab 9-3 year 2001
I have SAAB 9-3, TiD 2.2, 2001 year and my problem is next:Leterrs on my display computers are fading and disappear, so I cant see/read any information on it. Please help.
5helpful
3answers
How do I reset the oil life indicator on 2006 Saab 9-3
Switch ignition ON. Press brake pedal. Press button [A]. RHD - 100248. LHD - 100254. Turn button [B], until the message "System Settings" is displayed. Press button [B]. Turn button [B] until the message "Service Info" is displayed. Press button [B]. The message "% left of oil quality/days to service" is displayed. Turn button [B] until the message "Reset Service Ind." is displayed. Press button [B]. The message "Are you sure? Yes or No" is displayed. Turn button [B] to select "Yes". Press button [B]. The message "service parameters updated" is displayed. Switch ignition OFF.
BUTTON B IS ROUND PUSH/TURN BUTTON
BUTTON A IS TWO DOWN FROM THIS
3helpful
2001 SAAB 9-3 SE won't send signal to start
Is your SAAB automatic? If so, it is most likely the Neutral Safety Switch. I have had the same problem, it is very common in automatic Saab 9-3 models made in 1999-2002.
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
