Cannot install program. inasmuch as correct code was inserted. An invalid code message was received. This occured after an iunfortunate erraser of disk. Program was working until errasure of disk. Can you help?
Its not that people are UNWILLING to help, this is a problem you would need to ask the support team of the software manufacturer.
I hope you can get some answers from them
Good luck
Download some programs like Skype are vulnerable when it's not running or invalid win32 application occur. Here are a reason why: * Maybe your Antivirus are very strong to protect on your system when it talks about downloading. * Next is keep your operating system clean or tuneup before downloading such file on the web. * Next is keep your system updated, for this reason there are some parts on the registry where broken and capable of not installing such skype programs. * Last is when it's still have the problem exist even one ore more programs that are displaying win32 invalid application, reinstall your sytem. That is all the best part when encounter the problem like this. Good luck!
0x000000C5: DRIVER_CORRUPTED_EXPOOL
Do you have logitech mouse, keyboard hooked up they say that may be the culprit.
An attempt occurred to touch invalid memory at a process IRQL that is too high. This is almost always caused by drivers that have corrupted the system pool. If you?ve recently installed any new software, check to see if it?s properly installed; and check for updated drivers on the manufacturer?s web site.
Disable any unused onboard goodies i.e. network card, sound, video if not in use. Disable com ports if not in use. Try to do the install with the minimum cards/drives etc. Then when the machine is loaded add the other components.
Microsoft defines Kernel32 errors as follows:
"The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space.
On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs."
