Cars & Trucks Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are tyre pressures for a Y reg ford tarnsit motor caravan 2500cc turbo deisel
Anonymous
Level 2:
Sergeant:
  • Expert 184 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
184
Questions
Helped
64519
Points
526
The tire itself, on the sidewall, will tell you the max pressure it should
have, or on the inside sticker on the doors will also tell you.
2answers
What is the correct tyre pressure for a 17 foot single axe pop top Regent caravan (tyre size 195-14)
I can calculate it with spreadsheet I made, call myself tyre-pressure specialist nowadays.
Depends on tyres maximum load and Pressure needed for that ( AT pressure 6pr 55psi/3.8 bar, 8pr 65psi/4.5bar or 69/70psi/4.75/4.8bar). and maximum speed of tyre given as letter mostly N to R for caravans.
Then from Caravan MPVW ( max permissable Vehicle Weight).
Or better real weight ( overloading is more rule then exeption and unequall load is possible.
But normal car tyres or XL/reinforced/Extraload are sometimes OK if they have enaugh maximum load for MPVW.
Will try to make picture of example.
1helpful
3answers
Tyre Pressure for Majestic 19.6 ft Caravan
Depends also on the kind of tyre.
For the maximum load of tyre nex kinds need next pressure , wich is called AT-pressure/maxloadpressure/reference-pressure , for up to maximum speed of tyre or if lower 160km/99m/h. This is not the maximum pressure of tyre.
Normal car tyre /standardload AT 2.5bar/36psi ( exeptions as low as 2.2)
XL/Reinforced/Extraload AT 2.9bar/42psi ( exeptions 2.8 and 3.0)
6PR( plyrating) /C-load AT 3.8bar/55psi EUR ( USA 50psi/3.4bar)
8PR/D-load AT 4.5/4.8 bar/ 65/69/70 psi
From E -load is not often used in Europe.
From this AT pressure you can calculate the needed pressure for lower loads . Made spreadsheet for it in wich I first add 10% to the assumed load before calculating.
Will give example picture
2answers
Caravan tyre pressure guide
HiAnonymous
I trust you are well
I would suggest you look at your tryes and see what the manufacturer specifications are for the weight you are going to load on the tyres, it depends on what tyres you have on your caravan, they all differ.
Hope this helps you
kind regards
2helpful
Tyre pressure "fiesta zetec 1.25 16v V reg. year
Moulded into the sidewall of the tire.
What is tyre pressure ford transit 330 lwb 2002
In the US, all vehicles have a sticker attached to the driver door post (some on the driver door) of inflation levels. Sorry I don't know the exact pressure, but hopefully you will find that info there.
1helpful
Power steering quit and so did power brakes. Vacuum?
Yea I worked for Ford and have seen this before. Your pump is cavatating. It has air somewhere in the system. Ford pumps are known for being noisy. To get the air out correctly you have to jack the front tires off the ground and while the engine is on turn the steering back and fourth with the cap of the pump. You need to get a small bottle of Fords Friction Modifier and put it in this pump after you get the air out. If your truck has Hydraboost steering then the hydraboost could have a bad seal init allowing the pressure to go backwards through the system. The Hydraboost system is easy to distinguish because it has hoses that go up and attach to the brake booster system. Some trucks came with these and some did not. Hope this helped.
X REG FORD FIESTA 12.5 ZETEC, I CAN FEEL EVERY NOOK AND CRANNY ON ROAD WHILE IM DRIVING ITS BEEN IN THE GARAGE TWICE BUT THEY CANT FIND ANY PROBLEM WITH IT.
are the tyre pressures too high - often tyres are inflated beyond maximum to save fuel at the expense of comfort...
Turbo just stopped working,no pressure on guage,no warning,2005 f-250 superduty,2wd,cummings turbo deisel,85,000 miles
A Cummings? Are you sure it is not a Powerstroke? If it is a powerstroke the check the little hose on the passenger side of the intake to make sure it is connected to the nipple on the manifold. Also check on the connector on the turbo that has two wires going to the vgt solinoid. Make sure it is plugged in.
2004 F-250 TURBO DEISEL OVER-HEATING PROBLEM
Pls Check....
Fan Belt For slip
Thermostat Valve
Radiator Cap
Water Pump
Radiator Blocks
1999 Ford mondeo 'turbo deisel' not working?
what doesnt work ? the turbo ,
they arnt the most powerful engine in the world but reliability is outstanding subject to oil , filters and cambelt changes, at the correct intervals,
the engine should give good mid range touque with a little smoke , if it doesnt the chances are the wastgate on the turbo is leaking especialy with the milage , but to be fair on a car that age i would probably put up with the lack of power than spend money repairing it providing its running ok
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
