Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on. Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:
If necessary, open iTunes. You should see the following "recovery mode" alert:
WARNING: DISABLING AN IPOD TOUCH WILL MAKE IT UNUSABLE UNLESS YOU PLUG IT BACK INTO ITUNES AND RESTORE IT. If you want to know how to disable an iPod touch:
Go to Settings> General > Passcode Lock >Turn Passcode Lock On > type in a passcode
Now, hit the button at the top of your iPod.
Try logging in with the WRONG passcode many times. This will disable the iPod touch.
Do I read your question correctly: you want to disable your iPod?
Or do you want to recover it from being disabled?
For the first one, to disable your iPod:
Turn ON the passcode-lock by going to Settings> General> Passcode Lock> ... and then, tap Turn Passcode On.
Now, to disable it, put your iPod to sleep by pressing the POWER button once. Then wak it up. You will be asked for the passcode before you can use it.
Enter an incorrect passcode several times to disable the device.
Connect to iTunes, go to the settings menu of your iPod (click on the picture of your ipod on the bar on the side.) Then click "restore my ipod's settings," or something similar to that. You will have to re-sync your ipod, but your password will be removed. hope it helps
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
more detail?
