Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
Posted on Mar 18, 2010
I have the POULAN BVM200LE 711482. Could you
I have the POULAN BVM200LE 711482. I got it used and I can't find the owner's manual. Could you please let me know the Spark Plug Gap measurement? Thank you!
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jul 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1814
Points
5
Champion RCJ-6Y, gap is 0.25 inch.
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
No Spark, plug is good
Hi
If you have a good plug in still no spark you will need to install a new coil.
Sam
What should the compression be on a poulan pro b/v
All 2 cycle single ring piston blowers need about 100 lbs to start
2helpful
What is the gap setting on coil for poulan pro pbv 200 le
It should be 0.010.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
I need an owners manual for model #bc3100
Go to... http://www.weedeater.com/poulanpro/indexAction.do?id=default Scroll down to Download Manuals on the right, then enter your model number. There you have the owners manual and parts manual.
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Poulan PBV200 LE
Probably a low compression problem.
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
