FixYa.com
Tags:
Fuji 36.7 GB Hard Drive
Hi my name is Kiran...
posted by ammakiran on Mar 10, 2008
my pen drive(EMPREX 2GB) is write protected ..... How to remove that write protection... There is ** switch provided............ whenever i try to write data ... it is popping up that " your pendrive is write protected ... Please remove it or please insert other device"
Thank You,
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 11, 2008
Not Rated (0)
dilipbagdi
Rank:Wiz Wiz
Rating: 85%, 267 votes
Hi Kiran
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb ..if its not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 18, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i am having same problem but it is in drivers\volumes
Solution #3
posted on Mar 10, 2008
Not Rated (0)
IB4G2008
Rank:Wiz Wiz
Rating: 81%, 1620 votes
hmmm...well..it's either mechanical switch on the drive, or it's an electronic switch in the system settings. do you have a manual on this?
Can you Help with these Hard Drives problems?
Hard Drives
I/O error
Then it says Device [1:0:0]... Answer This...
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Hard Drives
necesito driver de sonido
sony vaio instal? windows vista... Answer This...
Hard Drives
drive not detected in Mac
I had used the Maxtor OneTouch... Answer This...
Hard Drives
My external hard Drive DIGITAL...
My computer doesn,t noticed it... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
