Computers & Internet Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a driver for Princeton VL173 for Win 7
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jun 25, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
3027
Points
14
I came home one day to find my Princeton VL173 with a black screen. I thought I needed a replacement. Turns out that I needed a new AC adapter. I tried one from another device that had a very similar power out profile and it worked! 12 years old, and the display is still kicking. Hope this helps. By the way, the AC adapter was from an old HP printer that I got rid of some time ago.
  • Anonymous Sep 22, 2012
    I am running my Princeton 173 display in Windows 7 64 bit using the same driver I had in Windows XP. Perhaps Windows 7 had a native display driver and auto-installed, but I did not require to hunt down and install a driver myself. If you need driver diagnostics and support, I have had some very good results using Driver Navigator. It has a modest related cost, but it works very well. I hope this helps! -Steve
Cherwoh
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on Mar 15, 2010
Cherwoh
Expert
Level 2:
Scholar:
Answers
66
Questions
0
Helped
16377
Points
184
Try here:
http://www.driverguide.com
2answers
I get an error message regarding monitor resolution settings
It wants you to set your PC video resolution to the native resolution of this monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Princeton VL173 monitor (12V 4A) only stays on momentarily
Sounds as if you may be dealing with a power supply (AC Adapater) issue. I had one go out on my Princeton VL173. I wasn't sure whether it was the PS or the display that went back. One day it just went black.
I had a hard time trying to find a replacement power supply. Out of desperation I used an old AC adapter (power supply) from an old HP printer that died. It had the same plug, and the power output profile was very nearly identical.Oddly enough, it worked! It has been trouble free for many months now. And it fit within my budget. (free!)
If the power output profile on the HP adapter was not so very close -- almost identical -- I'm not sure I would have done it. Also, it may be that the two power supplies are not intended to be interchanged. But I can tell you that from my experience it has worked out great so far, and it has been a lot of daily use for a long time.
I hope this helps.
Steve
1helpful
I hooked up a vizio monitor and the same problem occurs as with the princeton. The screen turns to vertical lines of many colors and freezes there.
has to be your grapics card/drivers try updating drivers or making sure your card is installed properly. if nothing helps, your card might be going bad
New HP desktop goes through Post and starts Win 7 splash screen, then the monitor drops off.
1. Restart the Computer
2. Press F5 or F10 a few seconds after POST (and before Windows tries to load) to access SAFE MODE
3. In SafeMode head straight to Control Panel - System - Device Manager
4. Remove all drivers under Display Adapters
4b. Remove all drivers under Monitors
5. Restart the computer
If u are able to get into windows using generic video drivers, then the problem is resolved. It's time now to reinstall the video drivers for u video card.
1helpful
3answers
Out of range no display
Try pressing F8 when starting the PC, but BEFORE Windows starts loading. In the menu, select Safe Mode. Windows now startd with a very low resolution. You can right0click your desktop, select properties, then the Settings tab, and drag the reslution slider all the way to the left in Windows XP, or for Vista and 7, rightclick the desktop, sleect the lowest option, go to screen settings, and drag the slider all the way to the left.
After that, click OK, then restart your PC. Now you can try to increase the resolution step by step, and if it goes wrong start in safe mode and set it back a step. That way you will achieve the highest possible resolutioon (and better image quality)
I hope this helps,
Yannick.
A nid drever 17" flat panel display. Model VL173
You do not need driver for monitor, but you do need driver for video card. You just have to make sure to set the resolution on your computer to the monitor native resolution.
Princeton VL173 scrren blank
Sounds like the monitor took a power surge. Monitor is probably bad but try hooking up the power to the monitor on a different power outlet and see if it turns on, if not then the monitor is bad and would need to be replaced.
3helpful
2answers
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Top Princeton Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
