Car Audio & Video Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set the time on Alpine CDM 7874
How do i set the clock time on Alpine CDM 7874?
Anonymous
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Mar 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
44
Questions
0
Helped
13873
Points
117
Turn off ur unit then ull just see the time on then u can set it up!
I was wondering does the Alpine CDM-7874 have any code. I just bought a car with this system in it and it had a dead battery and the stereo is not working
There should be no code. If you can try to see if you can check to see if power is getting to the red and yellow wires on the back of the radio. If there is a reset switch, try pressing that. It should be a small depression about the size of a pencil tip on the face or a hole with a red switch behind the face on the subpanel.
How do I change the time on my stereo?
what's the model and make of the stereo that you want its time changed?
How do you adjust the time
Here is a link to the stereo's owners manual which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDM7874.PDF
2helpful
How do I set the clock on my Alpine stereo, Model CDM 9801?
From Page 6 of the CDM-9801 manual from Alpine's site:
http://vault.alpine-usa.com/products/documents/OM%20CDM-9801.PDF
1. In the Clock priority mode, press and hold the
DISP button for at least 3 seconds while the
time is displayed. The time indication will blink
2. Turn the Rotary encoder to adjust the hours
while the time indication is blinking.
3. When the hour has been adjusted, press the
Rotary encoder.
4. Turn the Rotary encoder to adjust the minutes
while the time indication is blinking. The time is
automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder.
I hope that helps.
Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
10helpful
With clock shown, press and hold the display button for 3 seconds. The time will blink. Turn the rotary encoder to adjust the hours while the time is still blinking. When the hour is set, press the rotary encoder. This will switch to minutes adjustment. Turn rotary encoder to adjust minutes. Press rotary encoder once minutes are set or wait 5 seconds and time will store automatically. Reference page 6 in this link to Owners Manual for Alpine CDM-9821.
http://vault.alpine-usa.com/products/documents/OM%20CDM-9821.PDF
1helpful
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
No Sound
There should be a fuse on the back of the radio. It needs to be checked.
WIRING ALPINE CDM-7874
I need a wiring harness that plugs into the back of alpine cd player cdm-7874 & a user manuel
2helpful
Setting clock
From the Owners Manual for the CDE-9874:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
