Forgot u computer password? I hope this can help you.last month my sister meet the same problem,and then we solved it as follow.We download a 3rd party utilities - Windows Password Recovery 6.0, which claim to recover forgotten windows password,No need to call a technician, no need to re-install anything, and certainly don't need to reformat. You can down it from: http://www.recoverlostpassword.com/ Hope this can help you! Good Luck!
You can use a program called EBCD or ERD commander. These are freeware. EBCD is great but a little tricky.You will have to use a image burning program to create the bootable disk.
You can go to my free site to download both of these.
http://freecompadvice.webs.com
If you have any questions about how to run the program just email me @[email protected]
Here's what you need to do if if your the "Administrator" account has not password (if it does have a password you will have to reset it or crack it, and you need tools for that - see further below):
Windows XP Home Edition or Windows XP Professional
loadTOCNode(4, 'moreinformation');
To log on to a computer as the administrator to reset a password, try the following steps.
If
you can log on as an administrator to reset your password and you can
now log on successfully, you have resolved the issue, and you are
finished. If you are still unable to log on, go to the "Next Steps"
section.
Note If the administrator password is set to a blank password, do not type a password before you click OK.
if you do not have the password for the "Administrator" account you need to use either one of these tools:
password/cracker tools:
I have used "ophcrack" and "pc login now" they are pretty good!
if neither work (which would be strange) you may have to connect the hard drive into another computer using a hard drive enclosure and get all your stuff out and reinstall the hd and then reinstall windows.
hope this can help you!
good luck!
Download ophcrack LiveCD, burn it to cd, then boot off it.. It will find your password
I hope this helps, if so please rate our solution.
Download and use Offline NT Password & Registry Editor to reset/delete your password!
For more info. go to here.
Cheers,
Pelu.
