This could be an indication that there is an error code flashing on the control board and needs to be addressed. Most newer units like this indicate a problem by running the room air blower to alert the homeowner something is wrong. Really! Without shutting off the power to the unit, look for a small viewing port that looks into the cabinet. You should see a blinking light that will blink a number of times, pause then blink another number of times. Once you get this number, say 3-4, look at the wiring diagram pasted on one of the door panels for a diagnostic chart. It will give you a starting point where to look for the problem. If you have one. Or you could have a bad control board or shorted wire. Make sure the air filter is clean since you will be in front of the unit, you would not believe how many times I have to charge $100 to replace a filter the home owner could have done for less than $20.
You are describing typically normal operation. The blower runs for a while after the temp is reached to cool off the heater. I am presuming you are on the "auto" setting and yor fan is not set to "on" ... right?
