How do you change the time and location on the gucci 237944 I16Q0 1065
I assume that you do not have any instructions, so the first thought is that you should be able to get some from your nearest Gucci dealer, or at least get them to explain how to do it.
If this is not practical, then try the following :-
(From the web site I couldn't see both sides of the watch but I am working on the assumption that there are two buttons on each side).
One of the buttons will be a "mode" button, which changes the watch into various setting modes (try the lower left(?) when you press the mode button the display should change e.g. the hours flashes; to change the time try the buttons on the right side.
Keep pressing the mode button to reach the location setting function. I expect that you will be able to scroll through a number of options (again, using the right side buttons).
When you have finished setting up, keep pressing the mode button until the normal display is reached.
Some experimenting may be required, have patience and good luck!
