Try and turn the ignition over ,and over,then stop,then try and start it,if it starts,then the fuel pump is loosing it`s prime,check the fuel pressure regulator.
If you only hear a click sound when attempting to start your vehicle it means that the starter solenoid is defective or the battery connections are loose. Some times the battery connections can be loose enough that the starter will not operate but the lights will.
THERE IS A YELLOW COLORED T SHAPED HANDLE TOWARDS THE REAR OF THE ENGINE COMPARTMENT, CHECK WITH ENGINE RUNNING AND CAR IN PARK, ADD FLUID THROUGH DIP STICK TUBE
try turning the key to the on position (not start) then to off 5 times quickly. this may reset it. on the 5th time the power locks will lock then unlock quickly if done right.
