Cars & Trucks Logo
Posted on Feb 20, 2010
2001 silverado, 5.3L. heater control stays hot,
2001 silverado, 5.3L. heater control stays hot, can't get cool air without turing truck off.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Aug 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
5343
Points
53
I have the same problem, I think the door inside the heater box gets stuck when you turn it to hottest setting. Try going 1/2 or 3/4 to hot and see if it recovers without turning off the truck.
2helpful
Temp sensor silverado
Yes it would overheat without circulation, but the coolant doesn't circulate through the overflow tank. That reservoir only gets coolant into it when the coolant gets hot and expands and pushes the radiator cap seal up to let coolant into the reservoir. When the vehicle cools down, the coolant contracts and the lower level in the radiator will siphon the coolant out of the reservoir back into the radiator. Coolant circulation is from the engine to the radiator and back into the engine...and also through the heater core.
You may have an air block in the heater core. Check by taking off the outlet hose at the firewall or at the engine and see if you have a slow steady stream of coolant, with the engine running and heater controls on high heat. If it was an air block, a steady stream should quickly start. If you get little or no flow, the core may be plugged and need flushing backward or replaced.
1helpful
2answers
AC blowing hot air one side & cool air other side
If it has dual zone temp. control it is most likely the heater control panel.
Heater is blowing cold air. I have a chevy 2001 silverado extended cab, long wheel base. what could cause this?
My truck had the same issue and from I have read, it is pretty common. I just felt the heater hoses under the hood. If there is one hot and one cold, with the engine running and the heater set to maximum, rapidly squeeze and release the hot hose for about fifteen seconds.I just did this to my truck and it "Burped" the heater core. I got instant LAVA HOT air!! I hope this helps.
1helpful
I have a 2001 Chevy Silverado 1500 Z71 truck. When I drive for more than 20 or 30 minutes with the heater on, it gets "stuck" and then blows only real hot air, even if I turn the air conditioner on high....
Do you have a hot water valve out by or on the engine usually you can tell by following the heater hoses the water valve will be in line or be coming off of the engine intake manifold, it is vacuum operated older valves can stick, try that first or if you have a vacuum gauge check to see if the vacuum bleeds off you can also manually apply vacuum and feel what the heater temperature does.
My 2005 chevy silverado 5.3 liter is overheating. It runs at about 250 from 0-45. Once i get past 45 and get some airflow it cools right down. i though my thermostat was stuck but shouldnt it stay hot at...
Yes, you probably have air in the system. Park uphill and run the engine with the heater on to get air out. Refill radiator. If air comes back or continues to bubble up in radiator, you may have a leaky head gasket.
2answers
I smell coolant when I turn on the heater in my 2001 Silverado. The heater will not get hot.
Your heater core is clogged, leaking, and/or going bad. If it was anything else in the cooling/heating system, you would not have the antifreeze odor. The heater core is located under the glove box. I hope this helps and good luck.
Please remember to vote 7c42499.jpg if this was helpful in any way. Thanks.
3helpful
I have a 2001 Silverado 1500 2wheel drive with
no this is not a thermo issue the heater controls are bad and need to be replaced ive seen this alot in general motor trucks and cars.thanks and good luck
1helpful
2000 Silverado Z71. Heater stays in hot mode.
There are a couple of things you can check, or have checked. Under the dash, behind or around the ac duct work, there is vacuum operated actuator valves, which open and close different doors to direct heat or cool air,one of them might be stuck in the heat position.But the first thing to check, if the truck is equiped with it, is the heater control valve, it is under hood passenger side connected to one of the heater hoses going into firewall.Move the lever in opposit position, if you get cool air,thats the problem.If it's vacuum operated,check for leak,if no leak,replace valve.
My truck dosnt get hot in the cab blows warm cool air!
I would check your heater control valve, that, or the core itself being bad, are the two most common problems I've had with Chevys.
1helpful
1999 1500 silverado heater
Sounds like the blend door in the ducting has failed, this door is what controls the temp of the outlet air by blending heat and outside air or AC cooled air.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
