www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
? 3:33
https://www.youtube.com/watch?v=8eglHvyNV3U
Oct 19, 2010 - Uploaded by FMIPRODUCTS
How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
Since it hasn't been used in at least 15 years, what you're seeing is the dust, dirt and spider webs that are being burned up by the heater. The strong smell is because of the clogged burners. Best suggestion is turn it OFF let it cool completely and thoroughly clean the unit. It may need to be dismantled some so that you can reach and clean everything. A shop vac with a house and brush attachment works well to accomplish this. Pay particular attention to the burner(s) and vacuum them several times. Dry clean everything you possibly can. Then reassemble the heater and relight the pilot and give it a try.
In closing, I must say, having been in the hearth business for 15 years, I' am totally shocked, that after 2 years of neglect, that a 15 year old gas heater would even light.
Look at your thermocouple. Is it glowing red from being heated by the pilot flame? Is the pilot flame blue or yellow? You may have a dirty pilot orifice that is not heating your thermocouple enough to keep it lit after the burner cycles off. A yellow flame will eventually burn the tip of the thermocouple, which causes more frequent problems and eventually it will not work at all. If you have a can of compressed air with attached straw, use it to blow out the pilot orifice (with the gas off) where the pilot flame usually burns. Then examine the tip of the thermocouple and see if it is still round and smooth. Jagged or irregular tips mean it should be replaced. A blue pilot flame and a new thermocouple should do it. Hope that fixes it for you. Douglas
ignition out of postion , it needs cleaning , end of ignition brunt off or too short, blocked pilot, ignition shorting out on heater causing short spark
I have the same htr in Mich. & have worked on gas htrs.for many years. Does the flame go out when you let go of the button to lite it? If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial, the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
