I have instructions on how to take the loose parts of my ''gracco toddler bed model 8000'' and making them into a crib. i need to know how to make it into a toddler bed now that my child is older. the problem is that gracco no longer makes cribs and cannot reprint an instruction maneul for me. it is designed to be made into 2 sizes of a crib and then finally a toddler bed.
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ [email protected] and I'll foward the instructions to you.
SOURCE: Crib to toddler bed instructions
I need instructions to transform my mama and papas Aspen Cotbed into a bed! We have lost the instructions! Can u help?
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
SOURCE: changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
[email protected]
SOURCE: Transfer Delta Luv Crib (Poma) into a toddler bed
the instructions should be pasted onto the wooden board that the mattress is on.
