Garden Logo
Anonymous Posted on Feb 12, 2010
Not cutting correctly - burning the branches - Poulan Garden
Stuart
Level 2:
Novelist:
  • Expert 99 Answers
  • Posted on Feb 12, 2010
Stuart
Expert
Level 2:
Novelist:
Answers
99
Questions
Helped
94519
Points
189
This is normally a sign of blunt chain, chain on the wrong way around or cutting wood that is too sappy or moist. Sorry if you are a regular/trained user and this seems patronising but it is the first things I would be checking if that was a fault on a cahinsaw in my workshop.
Testimonial: "you are correct - who would have guessed the chain could go on the wrong way. thanks"
2answers
How can I use a gas pole saw?
Congratulations on getting you a new gas pole saw! A gas pole saw is undoubtedly the most powerful of pole saw types. It uses gas for operation, heavy-duty bars, and chains and is effective for a longer working period. Since it is the most powerful; you can put your faith for pruning heavier and larger branches and trees.
So, you have chosen rightly. But, it is a matter of concern, if you do not know how to use a gas pole saw. Let us help you with this matter.
BEFORE YOU START
  • Make sure that the pole saw is safe and prepared to be used. The faulty ones can lead to a serious accident.
  • Clear the area where you would use your pole saw and where the limbs would fall. Any hazard should be cleared at once.
  • Be aware of the weather because the windy or rainy weather can turn your pruning into a dreadful experience.
  • Cut only one limb at a time
  • Avoid cutting branches that are thicker than 8 inches. Take expert's help in this matter.
  • Be aware of the kickbacks.
  • Always maintain the right balance and base. Hold the saw firmly and stay at your place rigidly.
These instructions should be taken into account before the start of trimming. After you follow the instructions given above, it is time to move towards pruning process. The steps below lay out how to use a gas pole saw.
STEP 1 As you hold the grip of your pole saw and make a balance of your position, make few jump cuts underneath the branch you want to cut off. Jump cuts are a necessary technique which is used before the final cut. It reduces the weight of the branch that makes the final cut easier. It can be physically challenging to cut from underneath. So, always pick a pole saw equivalent to your weight bearing capability.
STEP 2 Extend the height of the pole saw based on the height of the branch. Hold the pole saw vertically, take it up to the branches away from the ground and never forget to hold it properly. Adjust its position and let it rest on the branches. In the meantime, you can ensure your position too. Always keep the pole saw at your chest level.
STEP 3 Now, begin to cut perpendicular to the limb and try to make deep cuts as much as you can. Deep cuts will let you make the final cut and other cuts easier. It will also allow you to make faster cutting strokes. Readjust your position, and the pole saw if you face any trouble.
STEP 4 The last step is all about your safety. Check where the limbs are falling and move from that place as early as possible.
Do not lose hope if you fail the first time. Keep trying until you reach your full potential. Clean the work area after trimming is done. So, this is how you can use a gas pole saw. Keep pruning and stay safe!
More details open the link Guide on How to Use Gas Pole Saw
Apr 11, 2018 • Garden
2answers
What are some tips to cut tree limbs by a pole saw?
safety helmet
safety glasses
cut smaller branches first
cut small lengths
have a friend as a look out for power wires and other obstructions that branches can fall on
never cut while on a ladder
use a trestle and not a step ladder
Apr 09, 2018 • Garden
2answers
Mealy Bugs
Go here.
Jul 07, 2014 • Home
Why is my drill smoking when I cut branches?
Sounds like it is overloaded, could be if the chain is blunt. New rotor in the motor might be needed.
1helpful
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
There are dead leaves at the end of the branch. I don't known where to cut the branches.
Trim where there is a junction that offshoots, like where the branch splits off like where it makes a Y.
Aug 02, 2011 • Garden
3helpful
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
