Trendware TEW-432BRP Router (S4432514) Logo
Posted on Jun 28, 2017
Frequent disconnection using wireless router
I am using the Trendnet TEW-432BRP wireless router. But the connection keeps getting broken frequently.
Though I am able to connect to the internet wirelessly, it gets disconnected soon. I have to reconnect it which fails again after sometime.
I have been using this wireless router for the last 3 years without any problems.
I am able to connect to the internet directly through the ethernet cable.
Layllah Therion
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Jun 28, 2017
 Layllah Therion
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
0
Helped
5476
Points
83
If you live in a heavily populated area you might be experiencing interference try switching the wireless channel on the routers config page. if there's a choice for auto-channel try that.
5 Related Answers
Anonymous
  • 209 Answers
  • Posted on Apr 26, 2009
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
casinotech
  • 10 Answers
  • Posted on May 07, 2009
SOURCE: trendnet router tew-432brp
the best thing to do is go to there website and call their tech support.. theyre actually pretty good!!.. cause i have the same brand of router but different model.. i called them and they'll walk you through it..
Anonymous
  • 404 Answers
  • Posted on Aug 09, 2009
SOURCE: I have to disconnect and reconnect my TEW-432BRP router
Hi! please try to download the firmware of your router the routers website and upgrade the routers firmware.possible is. the firmware is corrupted..
Anonymous
  • 404 Answers
  • Posted on Aug 17, 2009
SOURCE: Trendnet TEW-432BRP wireless router doesn't connect to internet
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Anonymous
  • 404 Answers
  • Posted on Aug 30, 2009
SOURCE: how can I set up a speed stream 4100 modem/router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
1. click on start
2. run
3. type cmd
I HAVE AN IPOD TOUCH, BUT I CANNOT CONNECT throughh my trendnet. IT READS UNABLE TO JOIN THE NETWORK "TREDnet what can i do to get wifi connection. thanks
Depending on the version of your router (you can determine the version from the Trendnet support web site), there may be a firmware update for your router that will resolve the issue that prevents your iPod Touch from connecting to it.
There has also been discussions that simply reseting the router by disconnecting the power cord for a minute or so can allow an iPod Touch to successfully associate with a flakey router.
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
2helpful
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
No SOftware Driver for TEW-432BRP
What brand is your router? Check for the IP address of the router and default password (should be written on the back of the device). Then type the IP address into the web browser on your main desctop in the kitchen like that for example http://192.168.0.1 enter the default username and pasword and you are in the router's menu.
Set up wireless connection SSID is the name of your network that will apear when you search it, do not change any of the default settings exept the SSID , enable, and select password. Use the WPA2 and type in your desired password and press SAVE . Then go to your bedroom and try to find the wireless network you've just created. And connect. Good Luck
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
I have trendnet wireless router model TEW-432BRP.i switched on the power,but the router didn't switch ON long time.when i switch ON the computer and logout the computer several time,then long time only its...
It is because the Power adapter is not connected properly. If this happens again. Disconnect the power adapter cable from the router and from the power socket. Then connect it back again. The router will come on. It could also be because of power surge which might have stopped the system for a while
Can't browse my bank web site using Trendnet TEW-432BRP router.
When you are hardwired to the router you should disable the wireless internet access and enable the local area network.You should do the opposite when you are trying to connect to your router wireless.
Trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
Wireless router dissconnects
Upgrade the firmwire you will find-it on www.trendnet.com
Top Trendware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
