theharrisont, You state that...." ice maker stopped working after it flooded our kitchen floor." The water works because the water fountain dispenser uses a separate part of the
Water Valve. The ice maker portion of the water valve is defected and the entire
Water Valve Assembly will have to be replaced. Your problem is the dual
Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the
Water Valve Assembly). The significant info which you provided was that the ice maker flooded the kitchen which indicates the
Water Valve Assembly is defected. Failure to replace the
Water Valve Assembly will result in the same problem of flooding at some later date. Replacing the dual
Water Valve Assembly is just one step of several steps necessary to correct the problem. You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice. Before you reinstall the ice maker you must check the
Water Fill Tube that dumps the water into the ice maker. Because you said that the ice maker flooded the kitchen, then the
Water Fill Tube is probably filled solid with ice which must be removed. A hair dryer is a quick way to achieve this. Blow hot air directly into the end of the
Water Fill Tube which dumps the water into the ice maker. Note: Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice.
This should correct your problem
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/henry_239f63a136de60f0
