2005 Ford Ranger Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get my spare tire off my 2005 ford ranger xlt
Anonymous
Level 3:
  • Master 617 Answers
  • Posted on Feb 04, 2010
Anonymous
Master
Level 3:
Answers
617
Questions
0
Helped
241759
Points
2043
Hole thru bumber put rod thru turn to let down, by the license plate
fuzzypoker
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 14, 2012
fuzzypoker
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
322
Points
You use your jack handle to crank it down if you have lost your jack handle use a 16 inch 3/8 drive extension and ratchet to crank it down.
2004 Ford Ranger XLT Manual
A 30 second web search turned this up:
FORD RANGER 2003 2004 2005 2006 SERVICE REPAIR MANUAL
Grab it before it is gone
1helpful
2005 Ford Ranger A/c Clutch relay fuse diagram
Usually located under the hood in a black box that contains several relays. The owners manual will tell which relay does what.
2005 Ford Explorer TPS and Adavance Trac lights are on.
Yes, using a tire of a different size will likely set the lights. Not sure what your local emissions test requires, but I would not put a bunch of miles on the car with the spare.
Evap canister vent control solenoid location 1999 ranger
In a '99 Ranger the purge valve is not anywhere in the engine compartment. Not there. SO, I guess it is above the spare tire...<sigh>..will post when I find it in my 1999 Ranger XLT 3.0L flexfuel. Seems the '99 location is unique
2answers
Locate Fuel Filter on 2005 Ford Ranger XLT
on my 05 ranger v 6 single cab the fuel filter is located on drivers side mounted in the frame.
1helpful
What is the biggest tire i can fit on a 98 ranger xlt 2wd stock suspension
the biggest tire you can put without doing any thing is a 31x10.50x15 if you want to go any bigger you will half to do a lift
2helpful
2answers
I need to locate the canister purge valve and the
look above the spare tire under the back of the box
2005 ford ranger 4wd front driveshaft
NO when in 2wd the front tires will not turn. I have the same truck
Where do I put jack when changing rear tire
Put on e-brake and place jack under rear axle on the side of the wheel as close to it as you can
3helpful
3answers
Wiring Diagram for 2005 Ford Ranger XLT
I have wiring diagram. Respond with your email address or fax number and I will sent it to you.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
