if the actuateor is vacumed,you might have have a hose that came off or it has a split in it somewhere,check that.or if you have posilock hubs one or both may be wore out or lacking grease,they are easy to remove,just a hex wrench and snapring pliers is all you need,remove and inspect for obvious sighns of wear.
Start out with buying yourself a $25 book from the Parts House. The I would go to the front HUBS, secure & safety vehicle before you do anything, Clean, Inspect, Lune & Repair front Hubs as required, get the brakes while you're there. Check your drive line, axles, u-joints etc. Clean , repair , replace as needed. Check for Tranfer case Operation. Is there power going to the front Axle when 4WD is engaged? do you feel a change when you engage the Transfer Case? Have you checked the Power on the circuits? Have you Manual or Auto-locking Front Hubs? Answer all those Questions & read before you do anything.
It sounds like the electric motor for the 4 wheel drive may not be engaging. It could also be the magnetic clutch for the 4 wheel drive may not be working. This sounds like an electrical problem.
I had the same problem w/ my 99. If you have auto hubs, they work off a vacuum pump which is located under your air filter box..check to make sure it is working..is that is working it's on to the hubs..the locking hubs are the black caps in the center of each from wheel..they snap on and off..hard to take off without breaking a few tabs..the seal one or both may not be holding the vacuum created by the motor under the airfilter box. if one of the hubs has a vacuum leak neither side will work, it's all or nothing..aside from the electric parts on the dash and side of transmition that's about everything there is to know about 1999 ranger four wheel system.
