I am looking for the wiring functions for a 97 ford fiesta the wire colours are power: Black/green (large diameter) black/green (smaller diameter) orange/black black/blue Speakers: yellow/black white/black red/white red/yellow
If you have or can get a repair manual, it should have an electrical diagram of the wiring for the locking system on your vehicle. However, if its just a remote locking system for your car doors (I'm assuming that's what this is) then you need only wire it up fitting your current locking system. You will have Power (Red), Source (Yellow), ground (black) and if like a stereo system you'll need a "remote wire" which is a smaller Blue wire which would connect to the ignition IF you have auto locking doors after you put your vehicle into drive and they lock after so much time 10-15 sec or so. If not, there should be no remote wire needed.
1997 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
and im not sure if it has an amp but it has the triggger wire
you can buy,well we can,adaptor plugs to connect to the h/unit and to the wiring loom plug.normally its yellow=constant power 12v +,red=ignition feed 12v+,[some are other way round]black=earth,blue=power antennae,grey/greyblack,RF speaker,white/whiteblack,LH speaker,Purple/purple black,RR speaker andgreen/green black LR,,orange =illumination dash lights.Those are our standard colour codings,we get in New Zealand.
This are the colours 1993 Ford Thunderbird Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Orange/Blue Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5′ x 7′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Green Left Front Speaker Negative Wire (-): Black/White Right Front Speaker Positive Wire (+): White/Green Right Front Speaker Negative Wire (-): Black/White Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Pink/Green Left Rear Speaker Negative Wire (-): Pink/Blue Right Rear Speaker Positive Wire (+): Pink/Blue Right Rear Speaker Negative Wire (-): Green/Orange
FORD
P o w e r
Memory (+12v Constant)
Green Yellow
Ignition (+12v Switched)
Yellow/Black
Ground (-)
Black or Fat Red
Illumination
Orange
Dimmer
Orange/White
Power Antenna
Blue (varies greatly)
S p e a k e r s
Right Front (+)
White/Green
Right Front (-)
Green/Orange
Left Front (+)
Orange/Green
Left Front (-)
Light Blue
Right Rear (+)
Pink/Blue
Right Rear (-)
Green/orange
Left Rear (+)
Pink/green
Left Rear (-)
Pink/Blue
1991 Ford F150 Truck Car Stereo Wiring Schematic
Car Radio Ground Wire: Red or Black
Car Stereo Antenna Trigger: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
This should help you with more then just the constant power wire, good luck.
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
1997 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Illumination Wire: Green
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+
White/Purple
Switched 12V+
Black/Pink
Ground
Black/Green
Illumination
Blue/Black
Dimmer
n/a
Amplifier Remote
Blue
Antenna
Right Front
Front Speakers
6" x 8" Doors
Left Front (+)
Light Blue/White
Left Front (-)
Orange/Light Green
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
6" x 8" Rear Doors
Left Rear (+)
Tan/Yellow
Left Rear (-)
Gray/Light Blue
Right Rear (+)
Brown/Pink
Right Rear (-)
Orange/Red
1998 Ford Explorer Stereo Wiring
Constant 12V+
Light Green
Switched 12V+
Yellow/Black
Ground
Black
Illumination
Light Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
5" x 7" Doors
Left Front (+)
Orange/Light Green
Left Front (-)
Light Blue/White
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
5" x 7" Rear Door
Left Rear (+)
Gray/Light Blue
Left Rear (-)
Tan/Yellow
Right Rear (+)
Orange/Red
Right Rear (-)
Brown/Pink
