.amp meter shows discharge andmotor won't turn over .new battery. this problem occurs when key is turned to start position.
With the key cycled on it is normal to see some discharge. If it is failing to start I would test the solenoid first. Quickest way to test it for fail to start is using a pair of jumper cable take one lead and attach them momentarily to each side (Large Leads) at once. If the starter turns chances are your start solenoid is bad.
The starter solenoid is found on the drivers side inner fender near the battery.
Use caution when jumping the two terminals. I usually attach one terminal to the positive on the battery and using a screw driver trapped in the jaws of the other end so it will make a connection and tap the screw driver tip on the lead side that is opposite of the battery side. Expect a few sparks. Can you start the truck this way? Yes you can if you have the key in the on position. If your starter fails to turn replace starter. If it does turn continue with the below suggestion.
The last check of this is to apply power to the "S" terminal of the solenoid. This is the trigger of the solenoid. If you get no click sound from actuating it replace it.
I would say the starter motor has a problem.Try tapping on the starter motor with a hammer,lightly,while some one tries to start the engine,the amp meter is supposed to discharge when starting,because the stater is drawing amps.The starter needs to be replaced.
