1991 Ford Escort Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a stereo wiring diagram for a 1991 ford escort four door sedan
Harvey N Tawatao
Level 3:
  • Ford Master 3,854 Answers
  • Posted on Jan 15, 2010
Harvey N Tawatao
Ford Master
Level 3:
Answers
3854
Questions
0
Helped
2796785
Points
16501
Good luck and hope this helps, keep me posted if you need more information.
Radio 12v dk. blue/red + radio harness Radio Ground black - radio harness Radio Ignition dk. blue/black + radio harness Radio Illumination dk. green (dimmer) + radio harness Factory Amp Turn-on red/black + radio harness Power Antenna N/A LF Speaker +/- purple - dk. blue/orange +,- radio harness or amp near radio RF Speaker +/- dk. blue/white - white +,- radio harness or amp near radio LR Speaker +/- white/dk. blue - red/dk. blue +,- radio harness or amp near radio RR Speaker +/- white/dk. green - dk. blue +,- radio harness or amp near radioI need a stereo wiring diagram for a 1991 ford - clear.gif
2003 Ford Escort ZX2 stereo wiring diagram please?
2003 Ford Escort ZX2 Audio Wiring Chart
MODIFIEDLIFE https://www.modifiedlife.com > 2003-ford-escort-zx2-...
Our 2003 Ford Escort ZX2 radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Ford Escort ZX2 Radio Wiring Diagram ...
2000 Ford Escort ZX2 Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
2000 Ford Escort ZX2 Stereo Wiring ; Antenna Trigger, n/a ; Antenna, Right Rear ; Front Speakers, 5 1/4" Doors ; Left Front (+), Purple ; Left Front (-), Blue/Orange.
Ford Escort Stereo Wiring Diagram
Pro Street Online https://my.prostreetonline.com > 2016/03/10 > ford-es...
Mar 10, 2016 - The Ford Escort was available through three generations, and today I'll be showing you our Escort stereo wiring schematic from 1980-2003.
3helpful
Wiring diagram to fit stereo in 1998 ford escort
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Ford sapphire 2lt 1991 module
Try and locate a Haynes shop manual.This will cover about 90%of the applications.
Cost is about$8.00-$20.00
1992 ford escort wiring diagrams
I have the instrument cluster diagrams, need an email address to send to in pdf format
1helpful
Need entire wire diagram for 1996 Ford Escort Lx
i want to wire up my towbar to a 1996 ford escort 5 door, i have the colur codes for which coloured wires come from 7 pin but need to know which coloured wires are for what on my car for rear light
6helpful
2000 ford escort finess audio wiring diagram
Here ya go, this should help ya out... Be sure to vote!!!!
2000 Ford Escort Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Purple
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): Dark White
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
1helpful
Wiring diagram ford escort for installing nav system and stereo controls
here is some info:http://www.the12volt.com/installbay/stereodetail/845.html
Need a wiring diagram for a ford escort stereo
Email me and ill send u a pdf which contains the standard wiring for a factory ford vehicle. (wire colors) that is.
4helpful
2answers
Fuel cut off switch for 1990/91 ford escort 1.9
The "inertia switch" which shuts off fuel to the engine in the event of a collision or jolt on a 1991 through 1996 models, as well as on 1998 coupes, is located in the rear of the vehicle, near the right (passenger's side) strut tower. On sedan and coupe models, open the trunk and remove the right-sided trim panel. On sedan and coupe models, open the trunk and remove the right-side trim panel. On hatchback and wagon models, there may be an access door secured by clips. On some models you may need to remove the lower quarter trim panel on the right side, however it is easier to cut an access hole directly above the switch.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
