I have never seen a dayton gas heater but I will try. If this is an LP Gas
System are you using a 30lb. Cylinder, 100 lb cylinder or a whole house
Tank.
Next are you sure you got the right gas unit for the right gas system?
If using LP gas did you put an external pressure regulator before the unit?
Next is the a hot surface glow coil or a spark system ignition system?
If you have to hold the controller down and press a button similar to a outdoor gas grille is it sparking?
If it is sparking,did you bleed all of the air out? This could take several
tries on a new unit. Does this have a wall mounted thermostat that
controls the heater? Finally check to make sure that the gas valve
is switched on if it has that option.
Good Luck
