I have a 1998 Mercedes E430. The car died... let it sit for about an hour and it started. Got it home... it wouldn't start again.. seems to start randomly. Sometimes it will run for 10 minutes then die.. sometimes 30+ minutes.
Last time it died I checked and had no fuel pressure when I removed the end cap on the fuel rail - nor when I cranked it. Checked the relays, pulled the cover off the fuel pump and it started.. ran for about 45 minutes.. now it's back to the same problem.
Also - won't start with starting fluid after it dies..
Check your gas cap it might not be venting the tank properly remove gas can and see if that helps
No change.. car started and ran for about 3 minutes.. then died...
