Asko 1375 Dishwasher Logo
Posted on Jan 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher does not drain after cycle
Asko 1375 is what I have
Timon Gr?nlund
Level 2:
  • Expert 126 Answers
  • Posted on Jan 27, 2008
Timon Gr?nlund
Expert
Level 2:
Answers
126
Questions
0
Helped
57500
Points
165
Check the drain pump and/or drain hose. It may be clogged woth something.
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Water didn't empty out after rinse and dry cycle
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
My ASKO 1375 seems to wash fine but will not drain. We checked the pump, filters and drain hose. All seem to be fine. Suggestions?
It is easy to have insoluble items clog underneath the lower spinner. Take it off and clean the holes thoroughly. Check for bits of glass. If this is not the problem, it could be that the pump is broken.
1helpful
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
1helpful
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Dishwasher doesn't drain at end of cycle
The drain time is programmable. If your manual doesn't show how to do it, you can possibly go to retrevo.com and find a similar one. I happen to have a model 1776 and used the model 1755 manual which is identical.
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
2helpful
Strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
1helpful
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
