Tip & How-To about Computers & Internet
1. Turn off the Computer
2. When you turn the computer on, repeatedly press F12.
3. When a boot menu comes up, select boot to Utility Partition.
3. Press Tab and than select Test System and hit enter.
4. There is than two options:
Express Test - 15-20 Minute Basic Test
Extended Test - Hour long Thorough Test
5. This is built in to all dell machines and it will save you from having to pay a lot of money to have your computer "professionally" diagnosed by computer shops.
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
