The float is most likely stuck or the switch is bad. The switch and float are usually in the plastic surge tank. Usually that tank comes off fairly easy, you could try taking it off and shake it that might jar the float lose.
But, if it sticking I guess I wouldn't rely on it, check the coolant level periodically.
Testimonial: "SINCE I ALL READY REPLACED THE SWICH IT MUST BE THE FLOAT WHICH I DID NOT KNOW ABOUT. THANK YOU."
SOURCE: low coolant light stays on, coolant level is full
Check coolant level sensor, sit in the coolant resv. tank has two wire that go to it, tap on tank see if light goes off, if it don't replace sensor easy to do, part run's about $12.00 - $20.00, part # FLS609 at NAPA. Hope this was helpful.
SOURCE: My low coolant light stays on all the time. I
I would think you could disconnect the sensor wire connector and use small piece of wire and jump across the 2 terminals.
