No sound. I purchased the x-540 about six month from now it was working fine until I moved to a new place. All connections are perfect but every time I tried to plug it to my ipod like I used to the mixer turns off? what could be the problem?
Hi Antex
You have to connect your iPod to the headphone input. that's it.
other than that I suggest a iHome speakers, a good ones, and great price. On Radio Shack
nice time
Carl
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
It sounds that the audio output section circuit to your TV has the fault. The audio output IC, or speakers should be suspected. Contact any service technician. If you're sound in electronics, and wish to get more details,
check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Hi Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge. If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped. Ash
You can try to recalibrate the battery but from the sound of it, you may be better off purchasing a new battery. You can get the brand name for about $110 average or a compatiable battery for about $80.
It sounds like the preamp wire that carries the left channel signal between the HU and the 2ch amp has an issue. Here's two quick things to check.
Check that both ends of the left preamp cable between the deck and 2ch amp is not loose or disconnected.
Swap the left and right preamp connections at the amp. If the issue stays with the left channel, the issue is with the amp. If the issue moves to the right channel, the issue is with the preamp cable or the HU's preamp output.
DO I HAVE TO GET NEW SPEAKERS FOR VISTA TOWER
THEY WORKED FINE ON MY OLD COMPUTER
NOW NOTHING
I HAVE IT TURNED UP HIGH ON THE MONITOR SCREEN BUT NOTHING.
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
