The 160 is celsius I believe. thats 160 x 9 devide by 5 & add 32 = 320 farenheit. ebay get a 150 to 170 celsius and you are good to go
The manufacturer Selco makes numerous thermostats and are distrubuted by Allied Electrical. I have been in contact with both companies to get information about replacing my KSD31 16/125~ 160 thermostat. I can't find the exact one. I am trying to find out if a similar but not exact one can be substituted.
SOURCE: need new electric cord for model 7000/a lakewood
Depending on handy you are, the power cords for heaters can be replaced, but may require soldering or other electrical and mechanical skills. You MUST replace the cord with one that has the same amperage and heat ratings.....that goes for the plug too.
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
