LG CHOCOLATE VX8500 Cellular Phone Logo
Posted on Jan 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My End Button Not Working My Lg Chocolate wont on because my end button is broken it just somehow stopped working and know how do i on my phone please help me?
  • AMYLYNNRIVER Mar 04, 2009
    I HAVE THE SAME PROBLEM BUT ALL MY BUTTONS ON THE FRONT {NOT THE KEY PAD} DOES NOT WORK FOR NOTHING...IM SO MAD BECAUSE I WANT TO READ MY TEXTS MESSAGES
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Feb 10, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416233
Points
13016
You need to have the keyboard replaced, take the phone to a mobile repair center and have them replaced it for you.
All the buttons on my LG RUMOR 2 wont work except the end button
Possible there is damage to the pad or the base board. Unless this is opened and cleaned the board damage cannot be confirmed. Also use a hair dryer to warm off any moisture that can cause this malfunction
1helpful
My LG-VX8575 chocolate touch screen is not working. I can only operate phone with side, send, clear, end keys.
check your belt of phone and touch plate's soldering.Some times touch plate soldering is lose or touch plate's belt might be broken so change it.
If problem still remains take your mobile to the mobile shop for flashing........
My phone isnt working
i work for a cell phone company, and to be honest with you i dont know how long you've had your phone, but it sounds like a default in the phone itself. i would contact my carrier, or customer service, and there are places that can fix phones, just do the research online for the locations. hope i helped
Camera doesn't work on LG Chocolate
Chocolates are garbage.. sorry. Go to verizon and get it replaced. If it's under warranty, it's free, and if not $55. I dumped my chocolate for a Voyager!
Lg chocolate
there should be arrow looking things on the side of your chocolate. if you push the arrow button pointing to the bottom of your phone... this should fixya.
End button
you need to replaced the keyboard take the phone to a mobile service center and have them replaced it for you.
1helpful
LG Chocolate Phone
Ok, I found something that worked. I read in another post that you can reformat the phone with a certain key stroke while the phone is off. I know in this case you will probably have to take out the battery, reinsert it, then do it before turning on the phone. I also had the phone plugged into the charger. I don't know if it helped or had nothing to do with it. Just thought I'd mention it in case it comes to that. Just hold down the * button, the 3 button, and the ok button. Then turn on the phone. Make sure you're holding all three of the buttons at the same time. I held them for about 5 seconds or so. It booted up normally after that.
1helpful
3answers
LG HBM 550 with Chocolate
Here is the problem, what most of the people do with this LG HBM 550 is press the PWR/END button on the headsent and when the headset light turn on Blue they let the button go and try to pair the device, this is worng when light is flshing Blue only it is not in the pairing mode.
You need to press and hold the button on the head set for five second and when the light flicker red and blue alternately, now device is in the paring mode.
Using you phone when to pair this device it might ask, depending on you r phone setting for the PIN or pass code which will be "0000"
Try ,,good luck
Regards
Chinmay
LG CHOCOLATE
1- first u have to uninstall verizon *288, than try ur music button, if facing same problem, than there is problem in u r keypad, contact lg care center
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
