SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
SOURCE: Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
SOURCE: my keurig machine is brewing only a little water
mcdevito75 here, You may need to clean the machine. water used to make coffee leaves deposits in the brewing holes and has to be cleaned out. Refer to the owners manual on cleaning.
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
SOURCE: I have had my Keurig B60 for about a year and a
We have http://www.youtube.com/watch?v=DqRs4Ott21s&playnext=1&list=PL88559E01E8136AA5&index=35 This one http://www.youtube.com/watch?v=nIBvzWWI-LY&feature=related If it does
here below a video link which is specifically for your case. The video is so
clear that we thing that any other words are useless.
will help if the above have not work out
solve your problem try also to do de-scale often
