My Breadman bread maker is broken. The pan jumps off the rotor. It appears to be missing a washer. However, I have no listing or breakdown of parts for this unit. Can you provide me with a parts list or better yet a diagram of parts for the TR2200C breadman machine?
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
If the pan is broken then you would have better luck trying to find the whole pan and not individual parts. Try ebay.
Hank
My pan jumps too!!! When I turn it on and it's kneading the dough, the pan jumps off of the system that turns the paddle. Did you ever find a solution?
Parts needed Bread Pan
