5 hp should have 20 oz.
When checking,
1) fill the oil to top of threads (if the inspection cap is threaded into the side of the block close to the bottom)
2) if it has a dipstick, wipe the stick as you remove it, re-insert *do not screw it down, just allow it to set on top of dipstick housing.
*note: you cannot overfill unit on an inspection cap
*** you CAN overfill on a dipstick. Any more than 22-24 oz, the engine will blow it out the valve cover breather hole.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Testimonial: "Quick,accurate response --- thanks"
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
SOURCE: Ariens 8.5 HP snowblower, 5
First I would take out the spark plug then try tugging on the rope. If no success take a ratchet and a deep well socket that fits the nut on the flywheel tighten and loosen the nut with out restricting the flywheel does the engine turn over? Does it move then stop after you loosen the nut? If it does then check the oil. If it is low or none in there then the motor froze up and needs replacement. If this was no help check in the shoot for obstructions like a newspaper stuck in the auger or the thrower.
Terry
