Could be two things and its hard to tell which it is. Either the GFI is defective or the disposal motor is shorted. I would replace the GFI first and if a new one trips then your disposal is shorted and needs to be replaceed
There is a short in the motor thats tripping the mains only a new motor will sort this out
Your boat anchor has seen better days.. best to get it replaced. garbage disp. are fairly inexpensive and easy to install... have fun -- goog luck..
Check the reset button..
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
heatman101
i
