You have to do this correctly or there's going to be a lot of smoke! The black wire is negative, the white positive and the green is ground. The 3-pin female XLR connector you refer to has the three pins where the charger plugs in. Position this connector to that when you look at it, the three pins form a V. The top two pins are directly across from each other, and the bottom pin is at the bottom of the V. The black wire goes to the top left pin, the white goes to the right top pin, and the green goes to the bottom of the V.
