Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Have you double checked the wiring ( + to + and - to -)? When hooked up correctly, a sub should push outward when bass hits. If your wiring is correct and your amp isnt too big for the speaker then its about to go out.
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
11-1/8"W x 2-3/8"H x 9-7/8"D
Wire your sub in bridged mode (4 ohm mono)
+ to + on amplifier
- to - on amplifier
(using bridging terminals)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
