I recently smelt a burning smell coming from my Eureka and after I cleaned the filter it seemed to go way, but not it will not even start. Can you please give me some feed back of what might be wrong? Thank you!!
I just bought a Eureka Altima and have only used it five times when I smelled an awful burning smell. I turned it off and then back on and now the brush won't spin! Any Idea what it could be?I just bought a Eureka Altima and have only used it five times when I smelled an awful burning smell. I turned it off and then back on and now the brush won't spin! Any Idea what it could be?
You can't post conmments that contain an email address.
The windings have a temperature sensor that "usually" resets when it detects an over heating problem. The other alternative is a light bulb in series with the motor that has popped, this will stop the motor from running.
I'd bet on the thermostat in series with the windings first though, can be replaced if you can get the cleaner apart.
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
This bagless model gets buildup of really fine dirt in the motor and starts to clog up the fan airducts. You will need to take the motor out and clean it.
The burning may be coming from the roller drive belt if the roller is jammed due to debris build up or has seized roller end bearings. Remove the roller and belt and examine both for damage. The roller, without the belt, should spin freely by hand. Replace the belt if it has a burned spot as it will fail shortly. Hope this helps.
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
