Apple iPod touch Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My iphone is showing a cd with a music note and aa usb cable and when i try to restore it it says error 1611
Jim Thomson
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Apple Master 1,099 Answers
  • Posted on Oct 15, 2009
Jim Thomson
Apple Master
Level 3:
Renaissance:
Answers
1099
Questions
0
Helped
276096
Points
2710
This article on the apple website may help
http://support.apple.com/kb/TS1275
2answers
I dropped my iphone 2g 16GB in a toilet bowl last month. I managed to dry it out but currently having problems in restoring it. ITunes just keep giving me errors like 1611, 1604, 23 and so on. I tried to...
Hey Chee, Usually an iphone with liquid damage may cause damage to internals that may go unnoticed if it is able to work. Depending on the error message you get when restoring with itunes may mean different things.
  • 1604 is just to check your usb cable to make sure its directly (not through a hub) connected to a usb 2.0
  • 1611 and 23 are usually hardware issues that cannot be solved with a restore
Mar 08, 2011 • Cell Phones
My iphone4 is stuck with the screen of a usb cable,CD and music Note.
Your iPhone is in restore mode. You need to connect it to you computers and open iTunes to restore it back to normal.
Trying to restore my iphone 3g and I keep getting a error 1611. Please help.
Try this:
  1. Plug/connect your device to a computer (PC or Mac)
  2. Turn it OFF
  3. Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
  4. Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
  5. Open iTunes and restore your device.
Warning: Restoring will delete all data on your device but this is the only way for you to recover it.
If you don't get it at first, try holding the buttons for lesser time or see the other procedures on my tip (link below):
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
1helpful
My I touch phone will not work....it only showa a
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message: now restore the ipod and it will be done.
If your iphonw was jailbroken earlier,you will need to jailbreak it again...
2answers
Ipod is stuck in recovery mode
Update and restore error messages on iPhone and iPod touch Last Modified: April 21, 2009 Article: TS1275 Old Article: 307219 Symptoms When trying to update or restore your iPhone or iPod touch with iTunes, you may see an error message in iTunes that stops the update or restore process. You may also see the "Connect to iTunes" screen on your iPhone or iPod touch:
The error message in iTunes may also include one of the following numbers (but is not limited to): 2, 4, 5, 6, 9, 13, 19, -18, -48, -50, 1002, 1011, 1013, 1601, 1602, 1603, 1604, 1608, 1609, 1611, 1612, 2003, 2004, -9808
Products Affected iPhone, iTunes 7 for Mac, iTunes 7 for Windows, iPod touch, iPhone 3G, iTunes 8 for Windows, iTunes 8 for Mac, iPod touch (2nd generation) Resolution Many restore errors can be resolved using the troubleshooting steps found in this document.
Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and:
Windows: Choose Help > Check for Updates Mac: Choose iTunes > Check for Updates
Restart your computer Simply restarting the computer can clear up certain issues that could prevent iPhone or iPod touch from being restored. After restarting, try restoring the device again in iTunes.
USB Troubleshooting Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built-in to the computer are preferred over a hub. If iPhone or iPod touch were connected to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If this fails, Restore on a different computer. If the issue is not resolved with the above steps, try to restore on a different computer. Ensure that the computer you are restoring on has USB 2.0 ports, the latest version of iTunes, and that you are connecting directly to the computer.
Advanced Steps
Make sure you have admin access
If your still having problems estore using a new user account Create a new user account on your computer and try to restore while logged in as the new user. iTunes will download a new version of the software restore file. After creating the new user, log in to that account and open iTunes and attempt to restore to see whether the issue persists in this new user.
Windows Vista and Windows XP
From the Start menu, choose Control Panel. Open User Accounts. Select Create a new account and follow the instructions to complete the account setup process. Once the new account is created, choose Log Off from the Start menu. Log in to the newly created user account.
When a restore issue is specific to a user, it is likely due to an unusable .ipsw file. The ".ipsw" files are what iTunes uses to restore your iPod or iPhone. If those files are unusable, then try deleting them so iTunes can download a new copy of them. Creating a new user will also cause new .ipsw restore files to be downloaded in the new user. You can find the ".ipsw" files in these locations:
Windows XP iPod touch: C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPod Software Updates (If you don't see the Application Data folder, you may need to show hidden files by opening (My Computer) Click on Folder Options. in that window click on the view tab, and make sure that show hidden files is selected.
Windows Vista iPod touch: C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates (If you don't see the AppData folder, you may need to show hidden files)
1. Open Folder Options by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options. 2. Click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click OK.
After removing and reinstalling the latest version of iTunes, try restoring iPhone or iPod touch again in the origonal user account.
As an added note, If running Microsoft Windows XP and the issue is resolved on another computer, but you continue to experience difficulties on your original computer, you may want to update or reinstall your Windows USB drivers and then try restoring iPhone or iPod touch again.
If none of these steps work you will need to contact either apple at
1-800-APL-CARE (1-800-275-2273)
Or another service provider of your choosing to get the ipod touch serviced or replaced.
Corrupted iTouch
Advanced Steps
I hope this article is very helpful for you and easy to follow. Good luck :)
4helpful
3answers
Iphone will not restore
Try restoring in DFU mode, which is different than recovery mode. I happened to stumble across it while trying to restore an iPhone 3G that a user unplugged in the middle of the 3.1 update. It kept showing an error of 1611 or 13 and wouldn't restore in recovery mode. I found this DFU mode option and the restore worked fine. The DFU mode keeps the iPhone OS from loading, so you don't run into as many compatibility problems. Go into DFU mode, then try restoring the phone and see if that works.
http://techierambles.blogspot.com/2009/09/restore-iphone-with-error-13-or-1611-in.html
To enter DFU mode:
1. Connect your iPhone to your computer
2 . Turn iPhone off. You may have to hold the power and home buttons down together to force the phone off
3. Once the phone is off, hold the power and home buttons together for 10 seconds exactly
4. After 10 seconds, release the power button but keep holding home until the computer recognizes that a USB device was plugged in
5. iTunes should detect your iPhone correctly, and also allow you to restore to the factory default settings
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
