I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
I have the same popper and the instructions. You do not need any oil. There is a circle lid piece at the top of the popper. You put the pop corn seeds in that lid and then pour the seeds in through the hole at the top. The popper needs to be off while you do this. Once you've added the popcorn you can then turn on the switch located on the back of the popper. It looks like a small light switch. The popcorn will start popping and it may smell funny at first if you haven't used it or used it properly. You have to monitor it and turn it off yourself- using that same switch. And per the manual you need to wait 15 minutes before you use it again.
We use ours all the time and love it. Hope this helps.
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
USING YOUR STIR CRAZY® CORN POPPER
Place popper base on flat, dry surface. The heat-resistant base allows for safe table use.
Preparing Popcorn
There are two models of the Stir Crazy® Corn Popper, one for making up to 6-quarts and the second for making up to 8-quarts of popcorn. Listed below are the proper amounts of oil, corn and butter (or margarine) to use for making various amounts of popcorn. Do not attempt to make 8 quarts of popcorn in the 6-quart model.
Quarts of Popcorn
Amount of Oil
Amount of Corn
Amount of Butter
1 Tablespoon
⅓ Cup
1 Tablespoon
2 Tablespoons
⅔ Cup
2 Tablespoons
6
3 Tablespoons
1 Cup
3 Tablespoons
**8
3 Tablespoons
1¼ Cups
3 Tablespoons
The usual way to use a pop corn popper is to:
1st - add oil
2nd - add popcorn
3rd - add any seasoning (if using the pre-packaged "theater" popcorn mix).
DO NOT add butter into the popper, as it will burn quickly and make for some foul tasting pop corn.
You can always add butter and salt to taste AFTER the pop corn is done popping.
