Cars & Trucks Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I purchase a repair maual GMC w3500
Where can I purchase a repair maual with wiring schmatics for a 2001 GMC w3500 box truck
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
Helped
16354
Points
207
Auto parts stores usually have them, like autozone, orielly's, kragen, pep boys, advanced autoparts, napa,...ect...
Do anybody have engine management wiring diagram for 2001 gmc w3500 diesel?
do anybody have engine management wiring diagram for 2001 gmc w3500 diesel?
I have a 2000 gmc w3500 gas motor that has spark and fuel in the fuel bar but wont start,,and even if i put ether in the intake it won't start
How is fuel pressure? He must try to start with ether, If you turn crank by hand forward and backward you feel how much play in timing chain?
01 w3500 gmc cab over trans wont shift into 6 th gear
Is there an over dirve button some where on the shifter or on the dash. On some of these there is an option to turn off over drive if you are hauling a heavy load/pulling trailer.
My 1995 GMC Forward,Signal lights blow fuse,4 way flashers work great.Where is the flasher unit on this veh.
a door in the back of the glove box (left side) It is in there 2. You can change this out yourself
2helpful
2answers
Where is flasher relay on 2003 gmc w3500
Flasher Relay is on the driver's side, under the dash, above kick panel, mounted in convenience center
How do I pull steering wheel 2001 gmc w3500. No bolt holes to use
You can access free repair manuals online @ google ebooks and autozone.com
3helpful
FUEL PUMP PRESURE FOR 2001 GMC W3500 5.7 L
with key it should be 57- 60psi without this much pressure engine will not start. once started it will run on 52 psi.
2answers
Fuel pump for 2001 gmc 3500 box van
The fuel pump is in the tank, there is one for each tank if you have dual tanks, also change the fuel filter with pump.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
