Hi. My name is Alex. I have a 1972 MB 600 with a Becker Grand Prix Stereo. The radio cannot be opereted from the rear passanger control panel. For the front radio control I need the power on/off switch.Can anybody help me find manual/wiring diagram for this unit. Thanks a million, Alex.
SOURCE: clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
SOURCE: Hi! Need help in removing the front panels of 2009
well to start you will nee an install mounting kit metra number 99-7423,
a wire harness 70-7552
and an antenna adaptor number 40-NI12
Now to remove the stereo you will need to pop off the trim ***. just below the heater control switches. the the vents above the radio. remove four phillips screws and then pull stereo/ heater assembly from dash.
