No there is in splitter cable, each SATA drive has it's own connection.
Testimonial: "I was afraid of that. Thanks"
No such type of cable..... however, depending on what you want to achieve (it's kind of obvious, tho)... there are SATA cards that have two or more SATA / eSATA ports. You can get eSATA cables and route them back into the case.
The cost for modifying might justify getting a newer motherboard (and cpu and memory)... Frys has such a mobo & cpu for $59 for the set. Memory for that set is around $20 for 2GB of PC6400 (800MHz)...
(Click on PC6400 to go to the Fry's website)
Just in case....
Testimonial: "I went to Frys but didn't find the combo. I will consider it anyway. thanks"
or you might have to download one
hope this helps
if you physically remove this sata ide card restart your computer then reinstall it this should activate the found new hardware wizard
http://download.cnet.com/windows-promise-sataii150-tx4/3000-18492_4-64684.html
Thanks
check outhttp://www.cablestogo.com/
