8.5" Sliding compund mitre saw: Model 137285940 Ser RDZ2031 Saw does not come on immediately sometimes when squeezing the trigger. Need a trigger switch. My email is [email protected] Paul Ottawa, Ontario, Canada
I am in Canada so my searches are normally weighted to Canadian suppliers. In this case none are .ca However Repair Clinic do supply to Canada and have a 1-800 number that states it on the Contact page.
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
rotating the laser in its' housing moves it left and right. The hexagonal bolt on the sides needs to be loosened to do this, then it can also be adjusted up and down. Make sure the trigger to the saw is locked before doing this.
I would go to Ereplacementparts.com and type in your exact model number (there are about 5 saws) and they you can download a schematic of your tool. Hope this helps.
