Hello there:
ok please try this boot the machine into the bios setup screen then go to the usb section and make sure that they are all enabled and after that save by pressing the f 10 and exit and reboot and then see if they work
best regards michael
Before proceeding to the hardware troubleshooting, start with the easy step first. Try updating the USB driver. Check the link below and see if you could use the USB driver:
http://driverscollection.com/?H=MS-6380&By=MSI%20(Microstar)
If the driver update did not do any help, then, you may not start checking the components (capacitors, resistors, transistors) of the board from where the USB port is going to the communication part of the board.
You may need to have an assistance from a tech that has the right tools to check them.
Have a great day!
SOURCE: My motherboard is MSI K9N6GM. It was working fine
Just give me 1- 2 hrs time...I am sending as I get it..
regards
SOURCE: ms 7142 Msi board, cant install xp with sata hdd
I think this is your board, K8MM-V. The following is the link to all drivers and info regarding said mobo:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=173
SOURCE: MSI MS-7507
That board is known to MSI as 945GCM7-L, and you can download the drivers HERE.
Thanks Mark
