Yes you can use the bluetooth with the PC and also use it with Skype.
1. You need to first pair the bluetooth headset with your PC
2. change the audio settings ie control panel > sound > audio > default device to bluetooth SOC
Test: open a winanp play the music if you can here the music then its working properly ( you can also search for help in Youtub ) : )
ALOK
No u cannot use it with your pc...
Dont forget to rate plz
Turn on Bluetooth headset and Blackberry hand-held.2
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
