Trouble Code: P1635
5-Volt Reference 'A' Circuit Malfunction
Possible Causes:
5v VREF circuit is shorted to sensor ground or chassis ground
5v VREF circuit, MAP or FTP sensor circuit is shorted to (B+)
5v VREF circuit shorted to EGR sensor High signal circuit
EGR solenoid valve (and sensor) is damaged or has failed
PCM has failed
The vehicle until warm runs off a different set of
parameters for the computer as far as timing and fuel are concerned.
Temp is not a problem at 200... and it is normal for the oil pressure
to lower once warm. ( as long as you have 10 psi oil pressure for
every 1,000 rpm's you are ok.)
The two codes cam/crank sensor are timing related related. So I would suspect something that deals with both sensors,Timing chain maybe?This particular engine has a problem with chewing up timing chains. If you find this to be the problem i recommend using factory GM replacement parts. I have had to re-do several that i tried to use aftermarket parts on. The only other thing that comes to mind , dealing with the drive ability, is the fuel pressure. These vehicles are sensitive in the fuel pressure area, but this should not make the light on the dash come on. You may have more than one issue. The other part of the vehicle that deals with timing is the ECM. If you have access to a scan tool with data stream on it , you can look and see if the ECM is receiving a signal.
