Computers & Internet Logo
Anonymous Posted on Aug 29, 2009
Hello sir my name is shyam
I don't have audio drives so kindly any solution(u8668 mother board,p4)
Anonymous
Level 3:
Brigadier General:
  • Master 7,191 Answers
  • Posted on Aug 29, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
7191
Questions
Helped
1334905
Points
22939
Hi Shyam,
You can download the required drivers from:
http://www.biostar-usa.com/mbdownloads.asp?model=U8668
Choose the audio drivers according to your PC operating system and download.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
I have u8668-d mother board name and i don't have the audio drivers because i lost my rivers cd so please help me .i am using windows xp sp2.I will be very thank full to you. regards ahmad mirza
Here is the sound driver ftp://ftp.biostar-usa.com/drivers/Audio/CI9739_512_WINXP.EXE and all of the other drivers can be found here http://www.biostar-usa.com/mbdownloads.asp?model=u8668+d Good Luck, Austin
5helpful
2answers
1helpful
2answers
If my idle air control system is bad what kind of problems could this cause? What would be the effects?
A bad IAC unit will cause poor driveablility and poor/high idle, and also stalling and starting issues. There is really no harm by being bad but during rapid deceleration if the IAC does not catch the RPM's the engine could stall out; not a good thing if you were going 60 mph. Remove the IAC motor and clean the valve and also the chamber that it goes into with a good throttle body cleaner and that should really help. Carbon buildup is a big factor in IAC failure. Most CEL will not show a malfunction code with a bad IAC motor.
2helpful
2answers
VIA RAMA U8668 (PRO) sound driver problem
You are going to have to physically look at your mainboard.
The reems of drivel you posted are all but useless, but for one line:
Motherboard Name VIARAMA U8668 (Pro)
This line ids your board as a Biostar U8668, but what you HAVE to verify is the Pro part.
Here are the downloads for a U8668:
(it uses a C-Media audio driver)
Here are the downloads for a U8668 Pro:
http://www.biostar.com.tw/supp....php3?name=U8668%20Pro
(it uses a VIA audio driver)
If you physically LOOK at your board as seen here:
http://www.biostar-usa.com/mbs...model=U8668&socket=478
You will notice that just above (or to the left when mounted in a case) the ram slots the model number is printed on the board, what you have to verify is if "Pro" follows the U8668, and then use the appropriate driver.
2answers
My computer mother board model number is aad28751-402
come with more qwestions about wath kind of card or you want to now the driver for it i do need brand name for your motherboard
[email protected]
1helpful
D 850GB MOTHER BOARD sound driver
Here's the webpage from intel.com where you can find all the drivers for your motherboard including sound/audio drivers...
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=486&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go!
2helpful
Soud driver software downloading
software for sound driver and LAN driver
Lost driver cd
Simple, look for some kind of reference to model name physically printed on main board, ie "GA-XX1239". Go to gigabyte's site, search via board model number, download audio, video, chipset drivers etc for relevant OS. Normally there's a pic of board so you have a visual comparison.
Goodluck
1helpful
5answers
No sound can
hello. sir. i have lost sound from my lap top Compaq presario C700 after installing windows XP. kindly help me. my laptop is also showing pproblem during installation of hard drive for same driver, every time i turn on my laptop. i donot have the installation mother board for the same laptop
Grand Canyon Tech
Grand Canyon Tech
