1999 Pontiac Montana Logo
Posted on Aug 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rear wiper won't work and rear door won't open.On my 1999 ponitac Transport. also need a location of fuse box. Gavin [email protected]
Anonymous
Level 2:
President:
  • Expert 169 Answers
  • Posted on Aug 29, 2009
Anonymous
Expert
Level 2:
President:
Answers
169
Questions
0
Helped
62958
Points
967
Poss bad wiper motor---fuse box under hood near battery & inside rt dash have to open passenger door to see
1helpful
I need to know how to repair or replace the interior fuse box guts on a 2004 GMC Envoy 6cyl I would like to know how to take out the interior fuse box guts to check to see if I have a short. The...
You don't have a short in the fuse box ! Before you cause more problems ,take your vehicle to a qualified repair shop . The fuse just supplys battery voltage for the wiper's . I guarantee it's not the fuse box . The fuse for the front wipers is located in the rear fuse box . FRT WPR fuse # 33 25 amp. The rear fuse box is located under the left rear seat. I would bet the pluse board on the front of the wiper motor is bad , not the fuse box . I have thirty years of GM dealer ship experience as a technician . Just because pulling the fuse turns them off doesn't mean there is a short in the fuse box , it's just cutting battery voltage to the wiper motor . Wiper motor pulse board is bad , these go out all the time an cause the problem your having .
https://www.partsgeek.com/catalog/2004/gmc/envoy_xuv/body_electrical/wiper_motor_pulse_board_kit.html?brand=ac_delco
Can't find switch for rear wiper. Rear wiper not working. 99 nissan pathfinder.
Check it wireing to open dickky. I think any cut on wire you found. Other check fuse off wiper in fuse box care fully.
Where is the windshield wiper fuse located for a 1999 chev suburban
WIPER fuse 25amp. instrument panel fuse box. Do you know where the I/P fuse box is ? Left side of the instrument panel , have to open drivers door to get to it .
2answers
Rear wiper notworking
Hey Joe , what make model an year vehicle ?
Wipers dont work my front or rear wipers do not work just bought the van what are the odds that they both dont work where is the fuse box located found fuses and relays under the hood but could not find on...
On newer cars the fuse box is normally on the side of the dashboard, next to the driver door, you need to have that door open to see the pop off cover. The fuses should be labeled on the cover, and/or fuse slot.
1helpful
Intermittent Wiper Relay Where is it located on a 1999 Jeep Cherokee?
look under the hood for main engine fuse box. should be a black box that contains the main engine fuses and relays.open lid and on the underside of the lid look for the wiper relay location.if your wipers are'nt working,check the fuse for the wipers also.if your wipers work on full speed,your problem may be in the wiper switch itself. thank you for choosing fixya.com
What fuse number for the rear wiper
The fuse for the rear wiper should be in fuse location 8 and it is a 15A fuse. It is located in the power distribution box under the hood on the drivers side.
Rear windshield wipers stoped working.
if you check in your owners manual it will show you where to find the location of fuse boxes and which fuse does what,but you test them with a test light and the key on.
The rear wind shield wipers wont work and the driver seat
for the rear wiper check fuses # 7 and #12 in the fuse box inside the vehicle.....as far as the seat one of the seat motors are bad and the only way to repair it is get a used seat or order a new seat tack from the dealer...the motors are not offered separate
8helpful
3answers
1999 Jetta fuse box
The fuse box in located on the left side of the dash, between the door and the dash.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
